Lightning protection for an isolated metal structure
I work at a coal fired power plant that recently installed a truck sampling station in an outlying area remote from anything by over 1000 feet. It's about 20' tall made of heavy structural steel on a concrete foundation. The purpose is to safely get to the top of the coal truck. There are no electrical parts on it nor are any in the vicinity. Would there be any reason to install a ground rod for lightning protection? Reference?
RE: Lightning protection for an isolated metal structure
2. LP system is not normally required by code, but recommended. Look up applicable fire safety codes to your region.
3. Lighting risk is independent of electrical installation in the building. The electrical equipment, if installed, only increases the potential losses from the equipment damage. But risk to personnel does not change.
4. Review with your insurance carriers. They may have some say.
5. If it is a steel structure, installing a LP system would be relatively inexpensive. Buying peace of mind is also important.
6. You do not want the person on top of the structure to become the lightning rod either. So the rods should be installed accordingly.
EEJaime
