Hole Table
Hole Table
We are currntly running SW 2008 SP2.0. The problem we are having is with a hole table. The hole table does not want to assign numbers to hidden holes and holes on multiple surfaces. The hole table also picks arcs which are not generated by the hole wizzard. All the holes were on the piece were placed with the hole wizzard.
Any ideas?
Any ideas?
RE: Hole Table
Can you post a typical offending part and drawing with a hole chart applied? I will see if I can give you some ideas of techniques to use.
Cheers,
Anna Wood
SW2008 SP5.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://www.solidmuse.com
http://www.phxswug.com
RE: Hole Table
Kevin
