Material library help
Hi, friends,
I have been working on FEA for a while. I've found material properties the hardest thing to set up.
Could anyone like to suggest an advanced material library?
For example: equation of state, material failure, etc.
Thank you......
Thank you......
Forever Young.....
RE: Material library help
please tell me what do you exactly wanna do?
do you mean a plugin for ABAQUS, sets up material properties?
Mohammad Shahbazi
www.OmranAfzar.com
A plugin will be great. A databass is also good.
Just wanted to set up correct material properties. I've found it hard.
Thanks.
Forever Young.....
How do you use test data to set up your material?
How do you plan the test?
Do I have to test real material every time?
Do you believe the results in material property point of view?
Forever Young.....
do you have any experience on python scripting?
it can be a good job..
Good Luck,
Mohammad Shahbazi
www.OmranAfzar.com
Forever Young.....
- what materials are you modeling?
- do you need elastic (stress-strain) properties, or strength properties?
- what type of material models: linear, plastic, viscoelastic, ??
SWComposites: every material properties that ABAQUS supports.
Mohammad Shahbazi
www.OmranAfzar.com
To say that you define every material that Abaqus supports is incorrect as Abaqus is a general purpose program and hence could support an infinite number of materials.
corus
Abaqus 6.8 supports material libraries that is a good method of storing material definitions and re-use them in different analysis.
Aamir
The point I want to make is that what data we should use. I did a water simulation using EOS (equation of state), material data was from internet (papers, articles, etc). But the result wasn't good. Water itself shrink a great deal after I apply gravity on it. It is just wrong.
It is often hard to judge the quality of the material data. And it is hard to know what material property should use too.
Forever Young.....
