Separating Aluminum and copper scrap
Is there a cost efficient way to separate mixed copper and aluminum
JL
RE: Separating Aluminum and copper scrap
There are also several different companies that make separators specific for CU/Al that operate using "Electromagnetic Induction"
h
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
JL
Flotation, if you can use a dense enough fluid. There are aqueous salt solutions with densities high enough to float aluminum, while letting copper sink. Some commercial vendors:
http://www.cargille.com/heavyliq.shtml
http://lmtliquid.com/price-comparisons.html
Recovery of the fluid for re-use is the catch here.
If not, then differential sink rates in a viscous fluid (you would need to process the scrap to get similar-sized particles).
Both technologies are probably best developed in mining applications.
JL
