Moving items from assy to assy
Working in SE20 and I have a problem. I have parts in a top level assembly, but I need them to be in one of the subassemblies. Is there a way to move them from one to the other without having to erase them from one and redo in the other?
SE v20 SP7 WinXP SP2
RE: Moving items from assy to assy
you can use the transfer function for this. See attached
image for the location. You have to select the part(s)
and then the function will become active
dy
It's really usefull but if you don't use it often can take a little getting used to sometimes.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Drag & drop is reserved for re-ordering.
To transfer or disperse it is a discreet command so there is no danger of accidently moving a part from one assembly to another.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
