specification on bitumen coating thickness
I need to specify bitumen coating thickness on steel pipe piles and the surface preparation of the steel pipes in order to reduce downdrag. Anybody knows where I can get some references on these?
Thank you!
Thank you!
RE: specification on bitumen coating thickness
The specification calls for 3/8" coating that conforms to ASTM D2521 Canal Liner Bitumen. It also specifies a primer conforming to AASHTO M116.
I had 2006 version but I did not see the specification. Is it possible anybody can attach a file or a link to it?
