CustomizingáNX5ágmlaunch.dat
Hello and good evening.
I need some information how to customize the gmlaunch.dat file
for using the gpdl-package of GM.
Thank you very much for your help in advance.
RE: CustomizingáNX5ágmlaunch.dat
I just did the install. However there are too many variables to discuss here. You should contact GTAC.
Call GM Supplier CAD support!
GTAC has nothing to do with the GM toolkit.
Ben Loosli
That's not exactly true.
Siemens PLM Software actually does provide distribution and installation services and support for the GPDL package and as such, if you contact GTAC they may be able to provide you with the help that you need, recognizing that at some point, we may have to redirect you to a GM contact since we are not responsible for the actual content or behavior of these tools, but often we can help people to make sure that they are at least being used properly.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I did contact GTAC for a issue we had a while back after we had to reinstall NX3 and the toolkit when my hard disk failed. They had all the answers I needed.
