Macros and internally saved parts
Can API be used to insert parts into an assembly as internally saved parts?
AddComponent4 and InsertNewPart2 both need the part to have a filename.  I have searched through the help file, as well as prior threads, but don't see much referring to internal parts.
RE: Macros and internally saved parts
By the way, I am using SW2008 SP5.0
