Flow depth at the spillway toe
This is probably an easy one but...
What is a suitable method for determining the flow depth at the toe of a dam spillway.
Should it be based on Manning formula or an energy method or else.
RE: Flow depth at the spillway toe
Depends on the spillway slope.
also depends on discharge and where you are measuring the depth. is it before or after the hydraulic jump?
Before the hydraulic jump (the corresponding depth after the hydraulic jump is easy to obtain).
I have this...:
V1 = (2g(Z+Ha-y)^0.5
Where
V1 = Theorical velocity at the toe of the spillway
Z = is the fall or vertical distance in ft from the upstream reservoir level to the floor at the toe
Ha = Upstream velocity head
y1 = Depth of flow at the toe
The actual velocity is always less than the theorical velocity due to energy loss involved.
Equations for hydraulic jump in horizontal rectangular channel (Chaudhry, 1993; Chow, 1959):
V=Q/(yB)      F=V/(gy)0.5     y2/y1 = 0.5 [(1+8F12 )0.5 - 1]
L = 220 y1 tanh[(F1-1)/22]        h = (y2-y1)3 /(4y1y2)
where:
B=Channel width (m), F=Froude number (dimension-less), g=acceleration due to gravity (9.8066 m/s2), h=Head loss (m), L=Length of jump (m), Q=Discharge (m3/s), tanh=Hyperbolic tangent trigonometric function, V=Velocity (m/s), y=Water depth (m)
