parametric dimension
What is the maximum allowable characters in a parametric dimension? My equation has 150 characters, it only lets me put in 132 characters.Is that correct? Can it be changed?
RE: parametric dimension
Try breaking the equation down with subelements and adding these subelements in your final dimension equation using the Parametric Dimension form on the constraints toolbar.
Fawkes
