SP3.0 Fully Released
Updraft (Mechanical)
I just happened to check and SP3.0 is out of EV and in full release.
- - -Updraft
- - -Updraft
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: SP3.0 Fully Released
For checking.
Standing
SolidWorks Pro 2009 x64, EV SP3.0
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600
That has been an issue for several years.
It's a PITA!
I usually have to uninstall both app's, reinstall SW then ACAD.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Standing
SolidWorks Pro 2009 x64, SP3.0
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Standing
Mechanical Designer
Standing
- There were drawings we couldn't open on SP1 but now we can.
- The Reload from Vault works now.
- My test users report fewer crashes than on SP1.
- Edrawings is working in the vault.
Mechanical Designer
You're refering to updating older version files to newer?
There's nothing wrong with updating the files as they're checked out and checked back in. I believe when you check out the older files and then check back in, it will want to bump the rev.
The advantage with using the task scheduler is that it will update the files without having to deal with upreving the files.
You should be aware that the on-line PDMWorks help files, recommends that if you use the task scheduler to update files, do it one folder at a time versus trying to update the entire vault.
Cheers
