GMAW Pre-Qualified Welds
I have a project where the special inspector flagged some welds because they were done with GMAW process. The welds are 3/16" vertical fillet welds. Is this procedure pre-qualified for this type of weld?
RE: GMAW Pre-Qualified Welds
However, that does not imply that the process may be used without a written WPS. All pre-qualified means is that no PQR is required, and therefore no mechanical testing.
You should review Section 3 of D1.1 to ensure all other prequalified requirements are met.
