detailed view: label reposition
Hello, I am using NX 4.0.4.2
I have a question about detailed view. To create one, I select insert detailed view, then FIRST CLICK will define the center of the view and SECOND CLICK the location of the view label arrow. After a detailed view is done, I would like to change the location of the label arrow. Curently the only posibility I found is delete the vew and create another. Is there a possibility to change the position of the arrow on the existing view?
I have attached a small picture to explain better what I would like to do.
Thank You,
Gabi
Thank You,
Gabi
RE: detailed view: label reposition
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
But that menu let me change the type of detail to: none, circle, note, label, embedded or boundary.
I want to keep this style with the arrow (label), but reposition the arrow somewhere else on the circle.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
Best Regards
Hudson
www.jamb.com.au
Thank You,
Gabi
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
