Deformation of rubber...
I am looking on an application which needs to compress a rubber tube, diameter 2" x 1.35", the rubber tube is then filled with liquid. Compressing the rubber tube will deform it such that it expand to a diameter of 8.9" when it is restrained by the surrounding pipe.
Let's say for now that the rubber is viton 80 (FPM or something similar). I need to know;
-- how long the tube needs to be? (initially)
-- what is the elongation at it's maximum?
-- which shape can one assume? (does it need to be steel reinforced)
some drawing or input on the subject would be appriciated... I can provide with more info if needed or if something is unclear...
Tommy
Tommy
RE: Deformation of rubber...
Thank's anyway
