Retaining Wall Design
Hi Guys,
I am a civil engineer with little experience in the design of cantilever retaining walls. Can you guys point me in the direction of design guides, resources, etc. as I may have a need shortly to design a retaining wall. As a minimum I would like to just have the knowledge.
RE: Retaining Wall Design
Seems sources like USACE, AASHTO, FHA, are so broadly referenced, you're likely to end up back there sooner or later anyway.
If you've picked up a PE Exam guide lately (McGraw Hill), the Structural Engineering In Depth portion has a few step-by-step problems that cover the basics (concrete, reinforcement, geo parameters).
One thing to consider is the broad range of materials and systems used for wall construction-- concrete and steel, wood, polymers. Many proprietary systems have 'manufacturer's' recommendations for design and construction.
Have fun...
