Excel formula problem
Hi i have problem with a formula in excel. It goes like:
=((KVROD((4*(C12^2))/(PI()^4)-((4*C12*(C8^3))/(27*(PI()^2))))-(C8^3/27)+(2*C12/(PI()^2)))^(1/3))-(C8/3)+((C8^2)/(9*((KVROD((4*C12^2)/(PI()^4)-((4*C12*C8^3)/(27*(PI()^2))))-(C8^3/27)+(2*C12/(PI()^2)))^(1/3))))
In mathcad it looks like this:
where; V is G12 and d is C8.
I got the formula working in mathcad, and have to do the same in excel. Can somebody show me a solution? I fear it something with complex numbers to do
Please help
Please help
RE: Excel formula problem
2 - what is kvrod?
3 - good luck. Just need to do the grunt work to check everything carefully. If needed break the formula into smaller parts and see if they give the required results.
3 - good luck. You just need to do the grunt work to check everything carefully. If needed break the formula into smaller parts and see if they give the required results.
Another thing that I've had help is to break the equation up into smaller chunks and then at the end I can combine the chunks with considerably fewer parenthesis (I started to try to match your parenthesis but I got lost).
David
For at least some values of V and d, the terms within the square root can yield a negative number, so that the whole square root term is a complex number. Mathcad seems to be able to handle this in its stride, and the complex terms seem to cancel out so that the total solution seems to yield a real number (at least for the few simple examples I have tried). Excel "chokes" when you try to evaluate the square root of a complex number, however.
You might have some success if you use the "IMSQRT" (complex square root) function instead of "SQRT". (You need to install the "Analysis ToolPak" Add-In to have access to complex functions in Excel.)
Hope this helps!
It is probably a matter of taste, but for those who find it easier to work with the minimum amount of brackets your formula can be reduced to
=(KVROD(4* C12^2/PI()^4-4*C12*C8^3/(27*PI()^2))-C8^3/27+2*C12/ PI()^2)^(1/3)-C8/3+C8^2/(9*(KVROD(4*C12^2/PI()^4-4*C12*C8^3/(27*PI()^2))-C8^3/27+2*C12/ PI()^2)^(1/3))
Best regards
Morten
http://www.excelcalcs.com/
d <= 3*(V/pi^2)^(1/3)
If C12 is the value in column C, row 12, , then let v = C12
Similarly, let d = C8.
Now prepare the equation using those values directly.
Check each component and the first answer .
This may be helpful: an up-to-date dictionary for Excel 2007 functions with 14 languages:
htt
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Best regards
Morten
http://www.engineering-4e.com
