Flat head question
Flat head question
I have an application where I need to attach a flat head to a shell. I go to Fig UG34 in order to get some design help - particularly wrt attachment of the head to the shell. The flat head is to be made integral to the shell. The ID of the shell could be between 1"-4". The min 0.375" radius speficied on Fig UG-34 (b-2) renders the design very unpractical for my application. Could anybody please advise what I should do?
How can I justify use of a corner radius less than the min specified in the ASME book. This is not a code application, however, we would like to design to the code.
Any advice will be much appreciated!
RE: Flat head question
gr2vessels
The idea of using the code allowable stresses is based on extensive studies, experience and tests in order to ensure the safe use of the mentioned equipment. Other than that, any calculation based on a approved method is acceptable to the code and the local legislation where you intend to use the equipment.
Cheers,
gr2vessels
With such a small diameter (but how comes that you can change it over a factor of 4?) you shall not be limited by the head thickness.
I mean that you'll find it easier to use a thickness 2 times or more than the minimum required.
Under such conditions (low diameter, high thickness) the stress induced in the shell by head deflection under bending will be negligible (not difficult to prove quantitatively).
Now that stress (or more correctly: that strain) is the main reason for providing a so generous radius by ASME VIII (only for larger diameters BTW, as correctly stated by gr2vessels).
This should be a logical way of proving that you stay within code provisions with a minimal radius.
Another consideration that I'll offer to you (but this is quite a personal position) is that, when in a structure you leave in place some excess metal with respect to the minimum required geometry, then you cannot harm vessel's strength, apart from considerations of low cycle fatigue, mainly connected to thermal expansion. So, if you have an excess thickness, you can consider that the radius you want to obtain is there, but is hidden inside the metal left.
As perhaps Michelangelo said, the sculpture is already there in the stone before starting, the only duty of the sculptor is to let it come out!
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
you may be able to calc to a different formula where the head becomes thicker and use less or no radious at all.
Thanks. I have tried using the Roark's equations. It predicts lowers stresses and hence lower thickness requirements since there is no way to account for stress concentration.
