end of character variable
with the following code, when NRuns becomes large enough e.g. 1000 the program stops at 495th iteration giving the following error:
'The end of the character variable in an internal file I/O statement was detected.'
Does anybody know what that means and if i can perform the iterations?
Thanx for reading.
CODE
program LOOP
implicit none
CHARACTER(LEN=50) :: string
INTEGER(kind=8)   :: NRuns,i,k,l
do i=1,NRuns
  ! read from SCREEN.OUT
  OPEN(UNIT=80,FILE='SCREEN.OUT')
  ! read line 25 as string of characters
  READ(UNIT=80,'(25(/),50(A))')string
  l = LEN(string)
  k = INDEX(string,'=')
  ! read value after '='
  READ(string(k+1:l),*)value
  CLOSE(UNIT=80)
enddo
end program
RE: end of character variable
program LOOP
implicit none
do i=1,NRuns
  ! read 24 lines
  do j = 1,24
  read(80,'(a)')string
  end do
  READ(80,'(A)')string
  l = LEN(string)
    if (l.gt.0) then
        if (k.gt.0.and.k.lt.l) then
          READ(string(k+1:l),*,iostat=ierr)value
            if (ierr.ne.0) then
              write(6,*)'error reading line:-'
              write(6,'(a)')string
            end if
        end if
    end if
  CLOSE(UNIT=80)
end do
end program
Thanx that worked!
You could also use end= instead of err=
"err="  isn't in the code !
"end=" would be useful in reading the file as with
read(80,'(a)',end=999)string
but not for an internal read where "iostat=ierr" is used.
Sorry, my mistake.
xwb, no problem!
