Meshing Gears with Different Pressure Angles
Is it advisable to mesh two gears with the same DP but different pressure angles? Both gears are 8 DP. The driving gear has 22 teeth with a 20 degree pressure angle and the driven gear has 66 teeth with a 25 degree pressure angle. The range of operation is 75 to 350 rpm. Thanks for your help.
cas44
cas44
RE: Meshing Gears with Different Pressure Angles
either a 20 degree tool or both with a 25 degree tool.
I think your post indicates this is not the case. At that rpm, I would go with both having 20 degree pressure angles.
