non conventional solids aspen plus
Hello everyone,
I am trying to create the databank for components that are used in my simulations very often. These components are not present in aspen plus system databanks. The components are coal, wood which are non conventional solids handled by aspen plus with component attributes.
how can i use enterprise database and specify attributes to nonconventional solids.
My goal is to create a databank which I can use instead of creating non conventional solids every time I start simulation.
I am using aspen plus V 7.1
Thank you and Regards
RE: non conventional solids aspen plus
Hello, aguajava
Sorry about that this is not an answer for your question.
But I think you could help me out to resolve my problem.
I'm very new to Aspen plus and tried to create a solid stream whose substream name is "CISOLID".  However, everytime I close window, substream name was returned to its default name "MIXED".  I want to creat a stream represents solids in bitumen ore. but I don't know how.
Could you please help me?
Thank you so much for your time in advance.
