Torque calculation
Torque calculation
I am struggling to understand how the units equate to NM in the formula below when calculating torque requirement for a motor.
torque = moment of inertia * angular acceleration
Given that:-
units for Torque=Nm
units for Moment of inertia=kg/m2
units for angular acceleration=radians/sec2
Therefore
Nm=(kg/m2)*(radians/sec2)
Given that:-
units for Torque=Nm
Therefore
RE: Torque calculation
The units of rotational moment of inertia as units of kgm^2
and not as you have written them kg/m^2
regards
desertfox
Tobalcane
"If you avoid failure, you also avoid success."
Tobalcane
F - Force
M - Mass
A - Acceleration
Basic physics and if it gets real crazy it would be statics. Kinetics is force in motion. The previous equation will not help you calculate torque as it relates to tightening a bolt. (when tightening a bolt, the clamp load is what your trying to achieve. 90% of the tq put into the bolt is lost between various forms of friction.)
Try
T = KDF
D - nominal diameter
F - force
K - nut factor (usually ranges from .03 to .35)
For calculating horsepower and torque use
HP = (2pi(Tq)(RPM)))/33000
this works for english measurements
Hope this helps some.
btw, this is a basic 1st or 2nd year dynamic relation.
Fe
The formula brettball is using is correct the relationship that :-
Torque= I * α
where I = moment of inertia in kgm^2
α= angular acceleration in rads/s^2
units :- kgm^2/S^2 radians are unitless
therefore we have (kgm/s^2)*m but kgm/s^2 = N
therefore we end by substituting N for kgm/s^2
torque = N*m
His problem I believe stemmed from writing the units for moment of inertia incorrectly in the first place.
desertfox
Fe
