Vacuum Stiffener Interrupted By a Nozzle.
We have a case where a vacuum ring got interrupted by a large integral nozzle / boot. Vessel diameter is 17' horizontal. Boot diameter is 8'. This obviously exceeds code allowed interruption. Is there a calculation method available to ensure the adequate moment of inertia provided by nozzle?
Or, can cases 13 or 14 of Roark 4th Edition of Chapter 14 on Elastic Stability provide a suitable solution? ( Case 12 is the basis for ASME formula for vac. rings I suppose).
Other approach could be if an FEA provide an answer?
your comments are appreciated.
RE: Vacuum Stiffener Interrupted By a Nozzle.
jt
Appreciate your prompt reply which is quite helpful. In fact the vendor has submitted FEA and we are evaluating it. I am checking to see if there is any direct reference to such a situation any where in Eng-Tips.
Janaki.
