coupling constraint
coupling constraint
I used *Coupling to make sure the one-direction
displacements Ui of the nodes on the same line(in 2d axisymmetric model) are the same, but the
question is the reference node can not be localized on the line.
If i choose a point on the same line as reference node, it is giving a warning saying that 'it can not be used as reference node'.
Would you please explain how can I tie the nodes on one line together sothat horizontal line remains horizontal at any point of time during analysis....
Thanking you in advance
krishna
krishna
RE: coupling constraint
corus
regards,
krishna
