call system command
call system command
call system command
i would like to run an program.exe through my fortran code in a folder different than my fortran code
I have used the following 3 codes but the system cannot find the file specified:
1.
call system ('folder\program <IN.DAT')
2.
call system ('\folder\program <IN.DAT')
3.
call system ('cd folder')
call system ('program <IN.DAT')
Could anyone help me? Thanx in advance.
RE: call system command
Have you tried including the full path name (including drive label)?
call system ('c:\folder\program <IN.DAT')
It doesnt work also when entering the full path like this:
call system ('C:\Users\kostis\Documents\COMPUTATIONAL PHYSICS 4th\PROJECT SCREEN3\screen3LOOP\folder\program <IN.DAT')
however i can create a file in the folder like this:
OPEN(UNIT=99,FILE='folder\IN.DAT',STATUS='REPLACE')
so i would expect this:
to work
Does
work successfully at the command prompt in a DOS window?
In the full path name instead of using the long name version with spaces try the equivalent short name version (8.3 format)
Like everything else, Sysyem does not like spaces in file or directory names.  Try
CODE
call system ('"C:\Users\kostis\Documents\COMPUTATIONAL PHYSICS 4th\PROJECT SCREEN3\screen3LOOP\folder\program.exe" <IN.DAT')
The
doesnt work in a DOS window so i shouldnt expect it to work throygh my code.
But then the
should work then but it doesnt also
How can i put these two commands in a single line?
The code by xwb didnt work:
does
program <IN.DAT
work at the command prompt in a DOS window?
Programs I write that pick up data file names from the launching command line don't require the < symbol , I use the standard fortran "call get_command_argument" to do this (without a <)
What error message did you get in the DOS window with folder\program <IN.DAT ?
The command
program <IN.DAT
works at the command promt in a DOS window
CODE
This won't work because it spawns two separate shells; the first cds to a directory and then exits, the second attempts to execute and then exits.  To put both commands on the same line, join them with &&
CODE
call system ('cd folder && program < in.dat')
It has been a long time since I did any FORTRAN, but at the back of my head there is a tiny recollection that with one of the compilers I used you had to use two backslashes ("\\") if you wanted to feed SYSTEM a string that was intended to contain a single backslash ("\").
HTH.
