carburizing vs carbides check location
Hello every expert:
A lot of specifications, such as AMS 2759/7 state to check case depth at pitch diameter, or far away from canners etc. But for carbide check, they never mention check locations (I assume specifications require to check everywhere). Sometimes carbides exceed the limits from specifications, especially at gear or spline tooth edges. So what is your opinion?
Matthew
Matthew
RE: carburizing vs carbides check location
rp
Thank you for your quick response. Do you know any specificaiton specify that?
Matthew
rp
a sample is section and that sample is to represent the parts per heat lot\load.
Network carbides have always been unacceptable in my experience. The fact that you have any carbides at all suggest a problem with furnace carbon potential.
