Equipment Frame Analysis
I have an equipment frame that is approximately a 12' x 10' bay. Historically it was always analyzed as a simply supported beam with two columns. The load is applied at the center span of the bay. Historically the columns were braced to prevent any lateral movement and movement out of plane. The connections are square bolt groups.
Due to seismic considerations there are now lateral forces in the plane of the frame and out of plane that are introduced into the system. If no bracing is provided to a secondary structure would it be appropriate to analyze this as a rigid frame and size the connections to develop the moments. The first analysis would be based on the actual live load on the center span beam. Secondly, we would check lateral loads applied to this system.
Welding is not in the picture because pieces of the equipment are cast iron. Out of plane conservatively I have considered the mass of the equipment at the story height and the resulting out of plane bending moment in the system.
RE: Equipment Frame Analysis
If bracing to a secondary structure is provided at the top of the frame, simple frame analysis makes sense and lateral forces are resisted by the bracing.
If bracing is not provided, a rigid frame analysis is performed....If the frame alone is not sufficient, cross bracing will be provided. Just trying to think through it...
Two routes you can take....1) be consistent throughout or 2) worst case for each member. The first sometimes makes the calcs more detailed for some of the components. The second is often overly conservative.
Hope that helps.
ZCP
www.phoenix-engineer.com
