What is the tolerancing requirement
What is the tolerancing requirements in reciprocating components? Like in a reciprocating compressor between the piston and cylinder.....
Johns
Johns
RE: What is the tolerancing requirement
I would have thought that the optimal arrangement was a compliant sealing/bearing medium which is rated for the duty cycle and environmental conditions.
you need to figure this first, then make sure your seal can handle the growth
also, if this is a air compressor, what climate will it be working in, hot and dry
will cool faster than hot and humid! so your opprating temps may go up.
