Decals in AutoCAD Inventor
I have been assigned the task of becoming a decal expert using AutoCAD Inventor.  The Tutorial on placing a decal on assembly components is quite vague. "add work features as needed to assist with decal placement" ???  I am able to wrap a decal on a part (.ipt) but the decal comes in much larger than it was designed.  I would appreciate any help in this area.
RE: Decals in AutoCAD Inventor
Think you will get a better response if you try the Inventor Forum
Dave
