Erosion of pipe by particle size in fluid
My client is producing gas and oil from a frac'd well. His concern is the erosion of the pipe due to the size of the solids returning with the fluid.
Does anyone know of a way of predicting erosion by particle size?
Almost Broken
RE: Erosion of pipe by particle size in fluid
max pipeline velocity for erosion control
v fps = 100 / sqrt(density pcf)
100 is continuous service value
The materials are listed with the erosion resistance increasing as you go down the list
Bronze
Aluminum bronze
Nickel
Alloy 20
Montel
Hastelloy C
316 stainless steel
304 stainless steel
K-Monel
17-4 PH
416
304/316
Inconel
440 stainless steel
Chrome tungsten carbide
Ceramic
Isn't he trying to flow too much gas?
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
