How do I plot a number of different outputs onto the same graph?
I have an m-file and it gives out various outputs when I change the conditions in the code. I have seen someone plot the different outputs onto the same graph using the same m-file but slightly changed each time. He did something like rename the parameter and type some plot commands into the command window eg...
plot (t/3600, A) ...
and then slightly changed the m-file, then
plot (t/3600, A2) ...
and plotted both resulting graphs on top of each other so they could be compared easily.
How do you do this. I'm having trouble with it.
I hope someone can help.
Alex
Alex
RE: How do I plot a number of different outputs onto the same graph?
hold on
hold off
- Steve
