Wall Contraction Joint to Brick Veneer
I have a concrete retaining wall with brick veneer. I am trying to detail the vertical contraction joint. The bricks are pinned to the concrete wall using dovetail anchors. Should the bricks overlap the concrte wall joint.
RE: Wall Contraction Joint to Brick Veneer
