GAS TURBINE LUBE OIL PURIFIER
Hi to everybody, I have to prepare a technical spec for the supply of a GT lube oil purifier (Ansaldo V94.3.A frame). Can anybody suggest where to find a similar document?
Thanks in advance.
regards
lottol
Thanks in advance.
regards
lottol
RE: GAS TURBINE LUBE OIL PURIFIER
Contact somebody like Pall that makes filters. Their engineers will send you a source control spec for some other customer's filter they make and you can use it as a guide.
http://www.pall.com/industrial.asp
Good luck,
Terry
Offshore Engineering&Design
Take your choice of manufacturer and then write your spec from theirs.
One way to ensure that the filter you chose is the one purchasing buy is to include unique features of the chosen filter as part of the technical specification.
JMW
www.ViscoAnalyser.com
