Table generated from configs
I am running SW 06.
I am using configs as routing steps in a manuf process for a giving assembly.  That is, each config is a step in my manuf, starting with, for example config " 1 prepare material"....ending with a config "20 final assembly" and I tweak the model along the way.
Is there a SW function that dumps the configs into a table?  It looks like the "part config grouping" under table properties is setup for assemblies where one would need to add many of the same part (each with the appropriate config) to take advantage of this.  This is too much work.
If not, is there a macro available?
Paul
