Company that cuts single crystal into (100),(110), (111)
I'm looking for a company that will cut a single crystal rod into specific crystallographic orientations. This is for academic research and I already have the metal rod. I'm also looking to do this as inexpensively as possible because I don't have direct funding for my research.
Sarah
Sarah
RE: Company that cuts single crystal into (100),(110), (111)
Plymouth Tube
Here is on approach to cutting your sample with a Diamond Wire Saw. I would talk to DWT about anyone doing small lot cutting.
h
Your local stain glass shop might have a small diamond wire saw. Any lapidary shop should have this type saw along with a diamond blade saw.
http://store.allstainedglass.com/gromwisablpa.html
You might want to call these people and see if they know anyone who will do cutting on a one off basis.
h
Here is UKAM a good source of information about your problem.
http:/
