Saving Autocad drg border template into SW2007
How do I do this. The drawing template is a multilayered DWG file. When I try to open it in SW2007 it goes through the "Create SW Drg Wizard (I have to play about with the scale something rotten). But when I try to save Sheet Format it all disapears. I've tried all afternoon to save it in different template formats but nothings working. When I try a slddrt then open it it all crashes.
Can you boffins out there help me on this one.
Cheers
Mick
Cheers
Mick
RE: Saving Autocad drg border template into SW2007
Try opening the template, highlight the border and all it's text, ctrl+C then paste it onto a drawing sheet in SW.
Flores
Are you in the Edit Sheet Format mode when inserting the DWG file?
This is a very common mistake.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08; CATIA V5
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Can you flatten multi layers to one layer - that might help?
Tools/Sketch tools/Modify
Chris
ctopher's blog
SolidWorks Legion
-handleman, CSWP (The new, easy test)
I drew it all again - far easier
A star for you, for stating the obvious. We tried importing AutoCAD templates into SolidWorks 11 years ago. After months of fight it, I sat down and redrew the SolidWorks template to match what we had been doing in AutoCAD.
Standing
SolidWorks Pro 2009 x64, EV SP3.0
PDMWorks Workgroup, SolidWorks BOM,
HP xw8600, 64-bit Windows Vista Business, Service Pack 1
Intel Xeon CPU, 3.00 GHz, 16 GB RAM, Virtual memory 166682 MB,
nVidia Quadro FX 4600
