grip question
grip question
grip question
can anyone tell me what the obj is suppose to be referencing in the call below?
obj = RCOMP/'filespec'[,'component name'][REF,'reference set name'][,csys][,LAYER][,IFERR,label:]
is it a string, entity or other ?
I'm trying to assemble an assembly of dumb solids from another system using the DNEXT command and the above command.
I know grip is not maintained anymore but it will work well for this project.
NX 3.0
thanks
Smitty
www.changes-consulting.com
RE: grip question
That would be an entity that would contain the component.
You don't need it when dumping a component into an assembly.
rcomp/'filespec' is the minimum required.
Ben Loosli
