Part coloring
Part coloring
Part coloring
When I add a color to a catpart some of the part does not change to the color applied?  I have tried reseting the graphic properties and applying the color again but that does not seem to work. Can anyone help?
I am running CATIA V5 R16
RE: Part coloring
How do you apply the color? on which level in the spec tree?
RE: Part coloring
right click on body,   reset properties
Forever Young.....
RE: Part coloring
search geometry by colour, select them, then set the colour back
Forever Young.....
RE: Part coloring
If you are viewing an assembly, you might have to reset the part instance to "no color" in order to see the color of the PartBody.
If you are viewing a part, reset properties should work. I always click the APPLY TO CHILDREN option.
RE: Part coloring
The problem usually occurs in Partbodies that have multiple boolean operations. I have tried the reset graphic properties and selected all children but this does not fix the problem??
The colors are set by a customer macro that I beleive selects Partbody and applies a color depending upon the layer that partbody is on.
RE: Part coloring
Have you tried the Graphic Wizard to analyze which features are what color?
RE: Part coloring
did you change the layer of the element / part body ?
if the color changes then you were right... there might be some knowledgeware involved in this.
If seen KW rule changing element color ...
Eric N.
