Flush grinding @ tranisition area
2 face plates (different thicknesses; 24mm and 28mm) of same longitudinal are butt joint, and the joint is ground flush.
Fatigue point of view; what are the consequences? My perception suggests that it is always reccomended to have a proper welding geometry (i.e. max 3mm depth of welding profile measured from the top of the face plate to the top of the weld)
Any ideas?
Gokhan
Any ideas?
Gokhan
RE: Flush grinding @ tranisition area
