Low alloy sheet availability?
Have been looking everywhere for sheet material equivalent to 387 Gr 11 to 22 ( 1.25 to 2.25 chrome) in 16 to 10 ga.
for higher temp application 1000F +or-
Cor-ten or A-606 type 4 does not cut it (average .4 to .6 chrome).
Stainless has too much difference in linear expansion for app.
any suggestions for a material with similar exp to C.S. available in sheet form? Mill run is out of the question for qty required.
RE: Low alloy sheet availability?
htt
Though about a ferretic metengr, and actually it's perfect for the app.(Boiler Casing)
The problem is I am uncertain about a 387 to , say 409 weld.
We would need to "field" weld around 700 linear ft of 409 to 387.
This is a 1/8" seal weld.
Would probably need to use a 309 or 309L rod, and I am not sure this is practical given the footage.
Perhaps mig?
Your thoughts? Am I on the right track?
