Genset Size Estimation
I have 4 nos of 300HP motors rated at 4160V. The details of each are as follows:
FLA = 39.28A
RLA = 239A
P.F. = 86.2% (100%Load), 83.9%(75%Load), 77.2(50%Load)
Eff. = 95.5% (100%Load), 95.6% (75%Load), 95%(50%Load)
RPM = 1800
S.F. = 1.15
Based from 80% loading, I interpolated the equivalent power factor to be 84.3%. Hence, each motor will be 300HP x 0.746 = 223.8kW, therefore (223.8 x 0.843)/0.955 = 188.66kW.
Motor Starting Power = sqrt(3)*239*4000 = 1655.84kVA @PF=0.15, the power will be = 248.4+j1637.1kVAR
at 80% Loading, 84.3% P.F.:
P = 188.66kW + j195.93kVAR
running kVA= 272kVA at 84.3% P.F.
For one motor starting with the rest of the motors running:
sKVA = (188.66kW + j195.93kVAR)*3 =(565.98kW + j587.79kVAR)
sKVA Total = (565.98kW+587.79kVAR)+(248kW.4+1637.1kVAR)
= 813kW + j2224.89kVAR
= 2368.77kVA
Neglecting losses and O/L capability, can we say that we need a genset with eKW = 813kW, kVARpeak = 2224.89kVAR
Now considering a genset capable of 130% short time O/L,
can I say that a genset with:
ekW =813kW, kVAR peak= (2224.89/1.3)=1711.45kVAR
or a 1894.73kVA genset min. rating will be ok?
Just trying to understand the concept and at least make a decent genset estimate. Thank you.
FLA = 39.28A
RLA = 239A
RPM = 1800
S.F. = 1.15
= 2368.77kVA
RE: Genset Size Estimation
Your approach is probably conservative, but a motor starting analysis is the best approach. You'll also need to know what voltage level is required for starting this particular motor and load.
"An 'expert' is someone who has made every possible mistake in a very narrow field of study." -- Edward Teller
I would appreciate any guidance on this, even if it is conservative.
On the other hand, if the generator application is for a dedicated MCC (no other power source)...will prime rated genset be ok or not?
What is the difference between prime rating and continuous rating? Is it in terms of duty and overload capability?
What is a typical overload capability for both engine and generator for a typical diesel genset?
Appreciate all the guidance and assistance I can possibly get. Thank you.
Continous: for peak shaving or other uses where the load is a high continuous percentage of the set rating.
Standby: For use during power failures or outages.
Here is a typical spec for a genset model P800P1 / P900E1.
380-415V,50Hz
Prime rated 800.0 kVA 640.0 kW
Standby rated 900.0 kVA 720.0 kW
Prime
These ratings are applicable for supplying continuous electrical power (at variable load) in lieu of commercially purchased power.
There is no limitation to the annual hours of operation and this model can supply 10% overload power for 1 hour in 12 hours.
Standby
These ratings are applicable for supplying continuous electrical power (at variable load) in the event of a utility power failure. No overload is permitted on these ratings. The alternator on this model is peak continuous rated (as defined in ISO 8528-3).
The P800P1 is the prime model and P900E1 is the standby version.
Prime rated models are more likely to have an oil cooler and a larger lube oil sump.
Sizing. Noting the 10% overload factor, it was common to size a prime set at 125% of the calculated maximum load. This allowed continued operation as the set aged and lost power. You may be able to delay an overhaul for a year or two.
Sizing I would hesitate to de-rate a motor for generator sizing.
My quick and dirty calculation would be;
1: Motor FLA = 39.28A
2: Base load = 39.28A x 4 = 157.12A (plus any other loads)
3: Motor starting load. = 200% of largest motor. 39.28 x 2 = 78.56A
Total amps = 157.12A + 78.56 = 235.68
Basic rating = 235.68 X 3^0.5 x 4160/1000 = 1698 KVA
Adding the 1255 safety factor this gives us 2123 KVA
But if we are using an F.G. Wilson set it is already rated for 110% of nominal so 2133 KVA / 110% = 1939 KVA
You will not be well thought of if 18 months or 24 months from now, the diesel must have an overhaul before the fourth motor will start.
Beware of using less than the full rated current for the motors. In another thread we have an issue with a motor that worked well for a time, but production increased and the motor can no longer carry the full load imposed on it. The same creeping load increment may drive up your motor currents over time.
That is about as small as I would recommend based on the information given. You may get by with a smaller set.
Order the Permanent Magnet Generator option. It will give you better motor starting and better voltage response to block loading.
A heads up, when comparing sets, check the fuel consumption of each at the intended load level. If the larger set can support the load more efficiently, the fuel saving may more than repay the added original expense of the larger unit.
A second heads up, when comparing fuel consumption from different manufacturers, check the Specific Gravity of the fuel used for testing. I once reviewed some fuel consumption figures and found one manufacturer to be 10% better across the board. It looked really god, but then I read the fine print. They were using 10% heavier fuel than the other manufacturers. When the consumption was adjusted for the SG of the fuel, the fuel consumption was the same as the others.
Bill
"Why not the best?"
Jimmy Carter
I noticed that for the maximum loading, you considered all the motors' FLA (4 motors) plus 200% of the largest motor load (for starting).
In my calculation, I considered 3 motors' FLA plus 600% largest motor load.
Hence, by comparison, you used 300% as motor starting.
My question is, if I have my LRA given and it is 600% of FLA, I am curious as to why you only considered 300% (equivalent comparison with my calculation).
It will be helpful for me since I remember reading another thread wherein the same factor was used by Marke.
Frequency drop is dependent on real power loading slowing the prime mover. Motor starting current is at a very low power factor and does not add as much real load to the prime mover as may be supposed. The real load is much less than the 600% current.
Voltage drop is not quite the same with a generator as it is with a transformer. A generator has a voltage regulator to compensate for voltage drop. The voltage dip when a motor is stated on a gen set is as much caused by a response lag in the voltage regulator as it is by I^2Z.
We accept a little more dip from a generator because it is so expensive to try to avoid any dip when a large block load hts a generator.
By the way, if there are no general lighting circuits or users that will be affected by motor starting dips, I consider dropping my 300% allowance to 250%.
On the grid, the frequency doesn't chang.
On the grid motor starting voltage dp is deterined by the transformer impedance and the "stiffness" of the supply grid.
On a gen set, the frequency depends on the response time and the droop of the governor.
The voltage depends on the response time of the voltage regulator (and the time to build up the current in the revolving field to compensate for the added current.
Bill
"Why not the best?"
Jimmy Carter
Based from your latest post, the reason why its only 300% instead of 600% for motor starting is because of the fact that the generator once the motor is started does not actually start it at its full voltage enough to draw 600%. Due to the response lag of the AVR, the motor may get started at a lower voltage and thus lowers the starting current at a certain percentage.
My concern is that the 600%rated kVA as starting kVA has a large kVAR content on it due to a low power factor. Hence, I was under the impression that the 600% will have larger effect on the exciter's capability or the kVA rating of the generator than the ekW rating of the engine.
See FAQ237-766: Generator Sizing for a Motor Load
Bill
"Why not the best?"
Jimmy Carter
Thanks for all the patience and assistance!!!
You are quite welcome.
Bill:
Thank you for reading it over!
