Finding Scallop on Sloped Surface when using Step Over
I am creating a Spreadsheet for our CNC Programmers to use as a reference for surface finishing. I am using step over as the input and scallop as the result. I have it figured out for a flat surface, but I am having trouble figuring out how to calculate the scallop for 30, 45 and 60 Degree angles. Does anyone know how I can do this or can point me in a direction to figure it out? I have attached the spreadsheet for review. The 30degree result is not completely accurate.
Thank You.
Thank You.
RE: Finding Scallop on Sloped Surface when using Step Over
http://w
Software For Metalworking
http://closetolerancesoftware.com
Thanks again,
Troy Marker
