Unsteady state heat-transfer
Hi All,
Here is a little problem on which I need your help.
This is a batch process.
A tank intially start with a temperature of -90 deg C and had to be heated up to -80 deg C in two hours. I'm considering a heat transfer fluid circulating through the vessel jacket at about 35 deg C, the return H-T fluid gets cooled up to 30 deg C and heated in a heater to compensate for the heat loss.
I can calculate the amount of the Heat transfer fluid required based on the heat load and physical properties.
I want to calculate the exact time required to be able to heat up the tank contents from -90 deg C to -80 deg C. Since it is a batch process, the LMTD gets lower and lower as the tank gets heated.
Assume there is a mixer in the tank to provide turbulance.
Your comments are appreciated.
Thanks in advance,
Timewrap.
Thanks in advance,
Timewrap.
RE: Unsteady state heat-transfer
Good luck,
Latexman
