Smoothness of Concrete Floors in UK
Further to closed thread194-222605: Surveying Smoothness of Concrete Floors, we found LSS is able to display concrete smoothness by calculating Deviation under a 3 metre Straight Edge (see NSCS National Structural Concrete Specifications, Section 7) from traditional survey data.
LSS (dtmsoftware.com) is also able to display deviation in level, deviation in level between 2 points and slab thickness from the same survey data.
