How to model this part?
I need to model this part :
I'm trying to use Revolve and and Extrude :
The question is How to trim unnecessary pieces? or maybe I should use another methods to model this part?
RE: How to model this part?
it's an NX5 part. Hope you can open it.
I revolved the bottom half with "stock" on top...
I chopped the swoop with an extrude(thats what the stock is for)...
finally, I revolved the top taper and united it.
Thats my guess!
JAY
I think Jay's solution to boolean three elements is otherwise the correct approach. It also appears from the image that the two tapered ends may in fact not be co-axial (slightly off centre). It wouldn't change the construction.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
