Electric Cars with wheel motors
Is it true that electric cars with wheel-motors (ie motor in each wheel) are destined to failure because they will break when the car goes over bumps?
RE: Electric Cars with wheel motors
Gunnar Englund
www.gke.org
You can still use a motor per wheel if you can mount each motor on the vehicle's frame and couple the shaft to the wheel through an axle with universal or CSV joints.
