Copy & Paste
Copy & Paste
Heving a problem with AutoCAD and Inventor copying and pasting...I used to be able to copy from AutoCAD and paste into Inventor part sketch without any problems, not anymore. No application options were changed or anything and my Edit>Paste option is not active. Anyone had this same problem or have a suggetsion?
RE: Copy & Paste
Have you tried restarting the computer?
Is the Translator-DWG addin loaded?
Can you start a new sketch and click "Insert Autocad File" from the 2d sketch panel?
