SW API vertex coordinates (GetPoint)
The below code finds all visible edges in a specified drawing view. From those edges, it determines start and end points and attepts to get the xyz coordinated of those points. It does not appear to be getting the correct coordinates b/c it fails on vertex reselection.
My goal is to collect coordinate data in an array which will be used to determine top, bottom, left, and right verticies on which dimensions will be placed (overall dimensions).
Any ideas why this is not pulling the correct coordinates?
'Get all visible components
vComps = swView.GetVisibleComponents
'Print name of first visible component
Debug.Print vComps(0).Name2
For comp = 0 To UBound(vComps)
    ' Get all edges on the first visible component
    vEdges = swView.GetVisibleEntities(vComps(comp), swViewEntityType_Edge)
        'Iterate through and select all edges on the first visible component
        Set swSelData = swSelMgr.CreateSelectData
        swSelData.View = swView
        For itr = 0 To UBound(vEdges)
            Set swEnt = vEdges(itr)
            'boolstatus = swEnt.Select4(True, swSelData)
            ' Get and select the "Start" vertex
            Set startVertexObj = swEnt.GetStartVertex
            boolstatus = startVertexObj.Select4(True, swSelData)
            ' Get xyz corrdinates of selected "Start" vertex
            startPt = startVertexObj.GetPoint
            ' Get and select the "End" vertex
            Set endVertexObj = swEnt.GetEndVertex
            boolstatus = endVertexObj.Select4(True, swSelData)
            ' Get xyz corrdinates of selected "End" vertex
            endPt = endVertexObj.GetPoint
            swModel.ClearSelection2 True
            ' Reselect "Start" and "End" verticies using coordinates
            boolstatus = swModel.Extension.SelectByID2("", "VERTEX", startPt(0), startPt(1), startPt(2), False, 0, Nothing, 0)
            boolstatus = swModel.Extension.SelectByID2("", "VERTEX", endPt(0), endPt(1), endPt(2), True, 0, Nothing, 0)
            ' Place dimension
            Dim Annotation As Object
            Set Annotation = swModel.AddDimension2(0.340726, 0.157093, -0.03995)
        Next itr
Next comp
