When to use 305mm HB kerb instead of a 255mm HB kerb
Hi, first post so go easy :).
I have started a new position with a roads consultancy in NI and am currently reviewing the standard details amongst other things for a proposed 40mph link road project.
I noticed that the in house standard details showed a 305mm x 150mm HB road kerb to be used but i always used a 255mm x 125mm HB in my previous schemes with other companies.
I have asked around the office and no-one seems to know why there is the difference. I have also checked the relevant BSs but they do not give clarity either. I do not want to go back to the client and ask a possibly daft question nor do i want to over specify something - can anyone here offer some guidance?
RE: When to use 305mm HB kerb instead of a 255mm HB kerb
I have to say we always use the 255mm high half-battered kerb (on the mainland), giving a 125mm (6") upstand. I believe this is traditionally to allow a 25mm surface dress at some point in the future, thereby reducing the upstand to a minimum allowable 100mm (4") for non-mountable kerbs.
However, I have seen a document which states that the larger section is preferred in heavily trafficked areas, eg urban streets, or where there is kerbside parking by heavy vehicles.
Sorry. Should have said that comment comes from a document called 'A guide to good practice for road edge details' by the Concrete Society (Concrete Society Technical Report No. 10).
