Layer question
Layer question
I apologize if this question has been asked already:
I am trying to figure out a way to turn certain layers on and off in paper space. For example, in model space I would draw on the following layers, which are on top of each other.
Foundations
Reinforcing
Pilasters
Base plates
Anchor bolts
Steel beams
Steel columns
However, I would like to have different paper spaces plot out the different layers without having to turn off different layers in the model space. I would end up with paper space tabs F1, AB1 and S1 with the following layers turned on for each (other ones that are not show for that layer would be turned off).
F1:
Foundations
Reinforcing
Pilasters
AB1:
Base plates
Anchor bolts
S1:
Steel beams
Steel columns
Is there any way this can be done? Or did I just confuse everyone?
Foundations
Reinforcing
Pilasters
Base plates
Anchor bolts
Steel beams
Steel columns
F1:
Foundations
Reinforcing
Pilasters
AB1:
Base plates
Anchor bolts
S1:
Steel beams
Steel columns
RE: Layer question
From paper space, type VPLayer at the command line and follow the bouncing ball...
HTH
Todd
RE: Layer question
Thank you TCARPENTER1 that has been driving me crazy for a while.
RE: Layer question
