input pressure.
input pressure.
Hi every body,
could you help me solving problem in Abaqus?
I have one model,(a tube). Input is pressure. the pressure depended by time. I want see the deformation of tube after take the pressure on the tube.(I want see the tube deformation will depending by time. Pls help me to define the input in this problem.
Thank you so much.
Thank you so much.
RE: input pressure.
Define pressure using amplitude. Then define aplitude - time dependency in amplitude definition.
RE: input pressure.
RE: input pressure.
